Shajota
- Whitsundays Qld
The AE started on the button this morning then conked out. Started up again but would only run on 1 cylinder with other one cutting in intermittently. Thought it might clear so took off but other cylinder would only cut in every now and then.
Turned around and took the orange one out so left it to sulk for the day in the garage....
Had a quick look late this arvo and grounding removed plug shows a definate intermittent spark. Sometimes would spark for a bit then stop all together. Other times just cut in spasmodically or very weak. Changed plug caps over and still persists on the same side and changing plugs made no difference.
Didn't have a chance to go much further but I presume it is either a condenser or Coil issue (or bad connection I suppose)?
The sudden failure seemed weird and didn't quite seem like a condenser problem but I am probably wrong. I will put in spare set of points in next few days to check but thought I'd ask for considered opinions here.
I haven't had a chance to check all connections (earths) and I understand these coils are usually reliable but I am betting on a bad coil.
I haven't searched here yet but is there an easy check for a coil?
Welcome thoughts.
Welcome thoughts.
