ha ha Phil, ever the saleman eh?
your joke might be missed by a few who dont realise that one of your design criteria, for the frame kit was to enable easy, in situ head removal.
I have even seen a frame with a hole drilled i n it to ease getting a stud out
Just hook the motor out for god's sake, if you are doing this in situ, you will allready have removed the carbs and the exhaust,plus other sundries so the only things holding the motor in place are a few bolts, some very easy wiring, and the drive chain, dont forghet the neutral light wire.
It is eevn worse if you are doing a 750 in situ, because you will have released everything except two bolts, so that you can hinge the motor down, that is even more daft.
