ngiles
- Sydney, Australia
I am in the process of re-installing the donk out of my 1200 after a Redax rebuild. All is fine except one small thing which relates to the sidestand engine bolt, which is the extended one supplied with the sidestand kit. This was on the bike before and I don't recall an issue then so I suspect I'm missing something obvious. When I tighten up the footrest bolt (A) the gap between the sidestand plate (B) and the frame is about 5mm wider (C) than the spacer, meaning I cannot tighten the engine mounting bolt (D) without padding out that space, or getting a new wider spacer. You can see it pretty clearly in annotated photo attached. Anyone got any ideas on what I may be doing wrong/what is missing? Ta, Nick
