We have done this Dell carb setup thing many times. Search the archives.
Set valve clearances, cam timing, and ignition timing accurately.
Make sure choke plungers actually hit bottom and seal.
Pilot jets anything between 50 and 65, most likely 55, 57.5, 60. Mixture screw with proper o rings, out roughly one and a half turns. That will look after starting and idle
Needle jet AB 265, needle K 1, middle notch. Slide cutaway? Those are your major factors, 1/4 throttle to 3/4 throttle. If you only replace one thing, replace the needle jets and needles as a set, biggest bang for the buck.
Accelerator pump setup, and slide bump? 60/2, 60/3?
Main jet, last and least, only affects from maybe 3/4 throttle to wide open. "1200" high comp, anywhere from 120 to 145. my bet is you wind up around 128 or so. But, my high comp 1200 with 4 c, open exhaust, open air box with thin K & N flat filter, after a LOT of dyno time, unexpectedly wound up with 145's, and pulls like a train at wide open throttle
Make sure you don't have any air leaks, and get the three carbs mechanically synchronized equally on the bench before you start, then vacuum balance.
