Jota 120 Gear Shift Lever
Bored with the gear shift lever (part number 43 305 080) losing its profile to cause a sloppy gear change, I have had a small batch laser cut from polished EN316 stainless steel. To give a bit more bite to the securing screw, they are also slightly thicker than standard. I can supply cranked or straight. They fit cross over gear change arrangements, Jota 120 and Series 2 Jotas and newer triples (I think).
If you are interested please pm me. £20 inc UK postage.
Cheers, Tom
Also used on series 1 engines with gearshift crossover linkage.
The one on my 1976 Jota was quite sloppy when I bought the bike, but I fixed it by building up the edges of the hole with weld and filing the flats back in them. Bit of a fiddly welding job and I had to buy a little square file small enough to fit through the hole.
