brooky
- PETERBOROUGH
Hi i am looking for a instrument mount for a 1979 jota if anyone can help, thanks
Hi thanks for reply, yes both parts if you have them ,no sorry peteborough ukThe metal hoops or the alloy bracket, or both?
Peterborough in Queensland?
Not so simple Cam, my hourly rate is $140, I reckon 2-3 hours to make that up, plus the materials.
I would like to tentatively order 3, contingent on my next lotto win.
In the past, I've simply welded a thick washer around the centre hole. It held out.Yeah, but I wasn't suggesting anyone get one custom made by a professional bike doctor like your good self, or an engineering shop. I was implying that it's a nice little DIY job.
If I wanted one, I wouldn't get you to make it for me. I'd do it myself. The hourly rate I charge myself is zero.
There's only a couple of bucks worth of material in it.
I've not made one from scratch myself, although it would be a simple enough job. But I've repaired and beefed up a couple that had broken through the middle hole. The original design is rubbish.
Have you got a busted one (or three) Vince? Send it to me and I'll make it better than it was, and I'll charge you the same hourly rate that I charge myself.
I do them with a brace across the front of the middle mount where they always break, giving the bike droopy clock syndrome (Viagra may fix droopy cock, but not droopy clock).
The brace bar is hidden behind the front of the alloy mounting bracket when it's assembled. Rivet counters wouldn't spot it.
That's what I did, on mine, forty-five years ago. No further problems occurred.In the past, I've simply welded a thick washer around the centre hole. It held out.
