Basketcase
Anybody fitted one of these after market electronic tachos?
I bought one cheap years ago because they are almost identical dimensions to the ND but I never installed on my SF2.
The original Z1000 wiring uses a ghost spark off two points sets to fire four cylinders every two revs.
The possibility is that this tacho (being for a Z1000) is calibrated for a single spark sensor, which produces one pulse per rev (counting the ghost). This would need two Lav 750 pickups combined, one from each spark wire sensor.
My bike is not running at the moment and any information would save me having to set up an electronic signal generator on the bench.
Rob
(edit: just found some information confirming this is designed to sense just one points wire)
Rob
