I've noticed on some topics that some of you have mounted a socket for lambda sensor on collector. That is obviously for Dyno purposes. I was wondering would it make any sense to fix lambda sensor permanently? It would not adjust anything, but there could be a lambda meter connected to it. That way you could monitor the air/fuel ratio during riding. Due to location, I guess the lambda itself would have to be 3 or 4 wire heated model. There might be just enough space on top of the collector, behind the gear box, just prior to silencer tubes. Any thoughts?
