What carb are you after? a dellorto MA16B . The same size carb is fitted to the morini Sbarazzino 98 and the Gilera Giubileo 98. Also if you are not fussed about originality the pit bike carbs work really well I have them fitted to my Morini and Gilera bikes. Will post a couple of photos . Also the dellorto MA 18 versions also work well ( as fitted to the 125 series bikes from several manufacturers)
Thanks for that advice and pictures, I will probably take that route as originals are a pain sometimes. I've got a mikuni on my Norton and it's brilliant. Thanks Dave
a bit on the carb settings needed at start up for the "Chinese" mikunis .One thing I noticed with the larger carb is the torque is limited at low revs but then at higher revs the bikes go very well. Some of the smaller bikes like the Gilera have torque tubes to increase the flow speed at low revs.
