Just bore the barrels out and slip 1200 liners in.Has anyone tried 1000 barrels on a 1200 bottom end?
Does it work?
I would like to try it but been told that there is a good chance of base gasket oil leaks.
I have 1200 liners with pistons which have too high a comp for a road bike.Just bore the barrels out and slip 1200 liners in.
In any case like that it is essential to measure the comb. chamber and find out exactly what compression ratio it has. It is vital for determining ignition advance etc. did they set squish, check all the other clearances?I have 1200 liners with pistons which have too high a comp for a road bike.
A Laverda expert rebored the bike and, without my knowing, fitted 750 pistons and had to machine the top edges off the pistons to miss the head gasket.
The result has been 3 batteries, a starter motor rebuild and continually rebuilding the starter clutch.
Total waste of time and money.
For a bike which is slower than before the rebore.
I also have a good set of low comp 1000 pistons and barrels - so if this conversion worked it would make a good reliable road bike, without further expense, which is all I want!
Sounds clever...I have 1200 liners with pistons which have too high a comp for a road bike.
No!In any case like that it is essential to measure the comb. chamber and find out exactly what compression ratio it has. It is vital for determining ignition advance etc. did they set squish, check all the other clearances?
Tell tale signs of a well known German bodger, hopefully not at large anymore......Sounds clever...![]()
Once came across a 750 fitted with what looked like Yamaha XS650 pistons (never found out what exactly), crowns had been "re-worked" with a wood rasp to fit the combustion chambers!
