michipons
- Palma de Mallorca
So.... as some of you predicted, I am starting my odisey in finding some parts for my 500.
I found in Australia a pair of carb rubbers in good condition, but i still need the air filter. I have the estructure that holds it in the airbox, but as it was clogged probably the previous owner just cut it out. Wolfang don't have them, but he mentioned that I can do one myself... any ideas suggestions? where to find air filter material that I can adapt to the filter plates?
Also one of the exhaust cooling rings is broken... the pipes are OD40mm with the balance pipe, so the rings have to be wide enough to enter and then using the 2 half rings. Are there standard aftermarket cooling rings I could use? or do I have to try some luck with standard Laverda providers?
Regards
Miguel
Regards
Miguel
