Lyndoneil
- Towcester uk
Does anyone know where I can buy a set of replacement stem seals.
Reassembled the engine (again), runs lovely now, but smoking fairly heavily from left side cylinder, I suspect one or more valve stem seals have dislodged
Although I will do a pressure test on the cylinders.
When I was rebuilding the cylinder head the stem seals preferred to grip the valve stem rather than the valve guide, I believe they are Honda stem seals as when supplied more suitable replacements was unavailable.
The only identification on the receipt is 097, were originally supplied by Richard Slater, who sourced them from elsewhere, not complaining, just explaining.
I've since learned that it's not totally uncommon for the necessity to glue the seals to the valve guides in some instances. What's your thoughts on this?
If I am going to need stripping the cylinder head again, then I might as well replace them with better seals if available.
