Lyndoneil
- Towcester uk
Having rebuilt the 500 top end, again!
Checked everything I can think of, reground camshaft, runout on cams measured, valve lash clearences, replacement cam follower, reshimmed valves, valve timing, ignition timing, time and time again.
It's back in the frame and ready to put some fuel through it and see what happens.
Strangely reluctant to, as up to that point life is tickety-boo.
As the doubts start, suddenly wondered if I've put the cam chain split link in facing the correct direction.
So! When viewed from the right-hand side (flywheel) which direction does the engine and consequently the cam chain rotate, clockwise, (I hope) or counter clockwise when running?
