Paul Marx said:But then, they never got much further than the factory gate.
I agree with Tippie, production bikes rarely attained the factory performance claims, especially the early triples and the air-cooled 750 twins. This was proved over and over again by contempory magazine road tests, dyno results often lacking as much as 10-12hp to the factory claims. Those claims were usually based on a properly set up and tuned, possibly blue-printed example, run on the dyno on a very good day, sun shining and all planets in line... rarely able to be replicated with a bone stock engine. In the case of Laverda, this changed with the introduction of the 120? engines. These consistantly lived up to the factory specs on the Moto Witt dyno back in the 90's.
Yes, the motorcycle engines of the day were in a pretty high state of tune, but running them at their max was usually venturing on very thin ice. Thousands of blown engines of all sorts back in the day are testimony enough. A comparably rare thing these days.
I see loads of potential in almost every old Laverda engine I rebuild and go to lengths getting valve seats right, inlet stubs lined up and carb/ignition settings spot on. Don't normally run these engines on a dyno, but the result is usually quite surprising for most owners.
