Good morning, new to this forum and we are working on a Laverda Jota engine and just wondered if anyone out there had some 75mm Mondial pistons and rings?
I can supply NOS flat-top 9:1 Mondials in 75 and 75.6mm, without pins, clips or rings. A very limited quantity of NOS ringsets available in 75.4 and 75.6mm. Clips are no problem, would need to check on gudgeon pins though.
NOS 10:1 Mondial pistons as used in the 120° engines available in 75mm, again sans rings, pins or clips.
Hi Piet, thanks for the message. We need piston rings as well, is there a possibility that you could get these? We could go for 75.6mm and get the cylinder bored. Regards Mark.
