The Three Dellortos
so a bit of a tits endeavor ?
Sort of like a side stand kill switch for the hard of thinking
Fucking waste of time .
Most people say that the SJCE starter is/was the one for the Jota 120. Mine came with an old Bosch one which may well be original. My best guess is the factory did what was logical and used up the Bosch starters on the Jota 120 and when they ran out went over to the SJCE.mauricejota7604 said:I notice that this starter is a early Bosch model, my 120 Jota has the later model alloy end plate starter, is that original fitment?
M.
I think this is quite handy. I have a habit going to neutral while waiting in traffic lights and always when I park, so no problem there. I'm going to give it a shot?Laverda SF said:By the way you Ground the Primary Low Current side of the Starter Solenoid directly to the Neutral SX on the bottom of the Tranny which is in Parallel to the Neutral Indicator Light and has nothing to do with the Neutral Light.
gtlsteve said:Never-less why can't Mr Sache/Witt etc have a feature in there nice electronic ignition that disables the starter button after say 1000 rpm and 5 second running, can't be that hard. Then you can start in gear when you stall at the lights.
The Three Dellortos said:so a bit of a tits endeavor ?
Finally got it to stop by disconnecting the battery, which by that time was pretty run down anyway.
