cape said:
Why do some Jota?s (like mine) have standard A11 camshafts instead of 4C? Is this a model for specific market area? If so, what other differences are there? Oh, the year model is 1981.
Regards,
-Sami
Hi Sami
looks like you are likely in Finland? For cams an 81 Jota could have had from the Laverda factory any of A12, A11, or 4C, and could have had flat top or high compression pistons. Depends on what country it was destined for.
A12's with flat top pistons would be the lowest power combination, and I would replace the A12's with anything else.
A11's with flat top pistons would likely give the best running, most torque, smoothest power of any of the original combinations from Laverda, really nice to live with, and easiest to run these days even on today's octane reduced fuel.
4C's are kind of "lumpy", they feel like they have a huge top end rush, likely exagerated by the hole in the torque curve lower down around say 4,000 - 5,000 rpm, so the top end hit is really pronounced. Add high comp pistons to that, and you get a really hard top end hit.
other options are a cam grind from Axtell, which seems to sort of combine the best of the A11 and the 4C, and Wolfgang and others have been offering a similar cam regrind.
then the later 120 motor cam grind, the F1 profile, has apparently been transferred by Keith Nairn to a cam suitable for a 180. This is the only cam profile I have no experience with in a 180 motor myself, but is one I would like to try. Perhaps someone who has run one of these cams, or Keith, can explain.
anyway, the A11's are decent, just not the fire breathing monster version of a "Jota", but if you want the fire breathing monster, easy enough to build that motor or swap cams or pistons, as so many others have done......
Paul LeClair
