Laverda SF1 cam chain
olly
The split link on the cam chain on my bike is a butchered. The cam chain appears in good condition but since it's all apart I think we'll replace the chain in it's entirety.
There's a diagram here if you scroll down a bit...
https://www.bearing-king.co.uk/bear...MIjejmqMqm9AIVR-d3Ch0yHQeNEAAYAyAAEgICNfD_BwE
mine measures
D1 6.32mm
B1 5.79mm
L 22.66
P 9.52mm
I believe it's 88 links.
Please could you let me know exactly what I should be ordering?
Before anyone says it, I did call Jason at 'The Chain Man' and it wasn't a definitive conversation.
Thanks.
Thanks.
Definitive? Not sure what you mean. Jason is in UK, and has the spec for Laverda chains. I have chains from him in my SFs. When fitting one to a stock SF2 his Iwis was too tight, something to do with the spec, and I got a chain from OCT for that bike. The chain that wouldn't fit that bike went straight into another SF without problems, I suspect it was an unskimmed head (most have been by now) and gaskets on the thick side - there is quite a bit of variation there.
I don't believe the head has been skimmed - I don't know if my gasket is thick / thin. If the chain's too tight then I can't use it right? Better to not source an iwis chain in the first place?
