Laverdalothar said:didn't I say take away the ones that have to do with battery failure? What has the ignition to do with a bad battery? You can't start the bike even if the battery is empty, so what do I care about ignition if I can't even turn the engine over?
Treating your battery as it should is one easy thing to do and not only helps on the ignition...
Oh - forgott: the 750 SF I restored also got DMC2. You barely had to push the starter button to make that beast bark into life. not one missing beat, one of the cleanest ideling bikes I have ever come across and nicely going up the rev range. That said, the bike hasn't covered many miles yet (I think 4.000 now, 4 years after restoration, me doing the first 2.000 in the first year...). The buyer did claim about the brakes, the suspension etc., but never about starting the engine or riding it...![]()
Electronic ignition won't do that, ignite, under a certain voltage. Points will fire with just a few measly volts.
A low battery isn't battery failure.
Any 750 will fire after a few months neglect with just a touch of the button.
Trickle charging a battery every time you lay a machine up for a while is a right pain in the ass
