I may have an answer to my problem(S). There was fuel in the oil, apparently from a leaking fuel valve. This diluted my engine oil and I am just guessing now, caused my clutch plates to stick. Perhaps the clutch plates had swollen? Does that sound possible? I drained the engine, cleaned out the filter basket and made a few new gaskets for the filter plate.
1) Is there any sealant applied on the gasket, or any other oil containing cover gaskets on the bike?
2) I am assuming I need to replace the clutch pack?
3) If clutch needs service, does it require any special puller, or other special tools?
4) If clutch needs replacing, would it be a reasonable assumption that I should get a new primary drive chain, just because the side cover is open.
5) I know I already need to replace my exhaust gaskets because there were none. I do have some spares. Any input would be a great help.
Thank you
Jim
