Laverdalothar
- Germany
well - that the radial works easier does not contradict with what I wrote. It simply is comparing different designs and mixing it with transmission ratios, which is not the best way to compare things. Anyway - as long as you found a solution that works for you, all is good! ;-)
I have a 13mm axial clutch master, actually the same as on the Zane 750 S Formula, paired with the PS16 from the same model for the P4 (4 piston callipers). Works very well, although I think I have the 31mm clutch slave piston. Clutch is a 2 finger actuation, brakes almost to good for me... (had a crash once due to overbearing on the front...). Very light compared to the original ones...
