Laverda triple pod filters
dynodave
UK
Has anyone had any luck finding some decent pod filters that fit under the tank on a Laverda triple? I'm running bellmouths at the moment but would prefer filters?
Thanks
Hello Dave, I have had K&N's on my Jota for ages and I think they work really well. They fit nicely and are not in the least restrictive on a standard motor. I wish i could remember the part number but I can't find it anywhere. The K&N website allows you to do a search based on the dimensions of the filter. If you like I could measure my ones and let you have the dimensions ?
Cheers !
Tom
I've had these K&N pods on my Jota since 1980.
The links are to the E-bay ones I also use, chinese, but work fine and reasonably priced., easily sourced.
I have a second set of these and just swap and clean them for the next time.
They are 48mm id to slip over the carbie thread and tighten with hose a clamp.
The large outer dia is 75mm, the smaller dia is 50mm, and they are 85mm long. Perfect fit, never had any problems with them. Clean regularly with K&N filter cleaning spray.
