sfcpiet said:You could rivet a couple of Guzzi timing chains together...![]()
You think like me, Piet
Just had this message from Jason Chain Man:
"Hi Craig, sorry these are no longer available from anywhere. Regards Jason".
Volki said:200 dollar for one timing chain??????????????????????????
Ventodue said:Gijs has recently managed to supply one apparently. Have asked if he has any more.
Dellortoman said:What's so special about the Zane cam chain? I presume it's a standard spec roller chain. Is there no other manufacturer that makes an equivalent?
sfcpiet said:So what's the big deal? Current Euro price is ?115, equates to close to OZ$190. <snip>
sfcpiet said:Pitch and width that is no longer used ? No idea what moved the designers to use it. :![]()
Dellortoman said:Thanks Piet.
Yes, that does defy logic. You'd think a common chain size would be an obvious choice.
Just out of curiosity, do you recall the pitch and width of the Zane chain?
Piranha Brother 2 said:I'd probably be adding a new centre piece to the list of 'mods' to go with big-ends ... or is the centre cam sprocket section part of a complete crank web??
Dellortoman said:Not sure about the 750 twins, but on the triples the cam chain sprocket is part of the crank, so I presume the 750's are made the same way.
Even so, it probably isn't beyond the realms of possibility to machine the sprocket off the crank centre, press a different one on and fix it in position somehow (keyed or welded).
The new chain/sprocket may have a slightly different pitch from the original, so the sprocket diameters might be slightly different. You'd need to make sure there's room for the new chain in the cam chain tunnel.
Dellortoman said:By saying it's do-able, you could be making work for yourself as the world's supply of 5/16" x 7/32" chain is exhausted. You might have to set up a production line pressing sprockets onto Zane cranks.![]()
sfcpiet said:Sure... I need that like I need a pimple on my arse.
