Rob
- Midlands, UK
Been having a bit of a tinker with the website navigation. I hope that it is fairly transparent to you all. But it means I now have everything under one application instead of two with multiple plugins to look after security.
So you can jump straight to the forum from the main https://laverdaforum.com website address You will then need to use the navigation index to open the list of forum boards that most of you will be used to seeing.
If you don't update your bookmark for the site (which is probably https://laverdaforum.com/xf) then you should automatically be routed to the same place.
