Led indicator bulb?
Readily available in Oz so no doubt same in UK. Be aware that they are polarity sensitive - have to be wired correctly - and the std indicator dash light, which operates by earthing through opposite side indicators, will interfere with your setup.
flasher units come with load adjusters these days, so you can regulate the rate of flash to your own requirements.
