Laverdalothar said:Piet, correct me if I am wrong, please, but if you leave the clutch lever alone, at least the main-gear-shaft gets turned with the engine and delivers resistance - no? So - theoretically, if you pull the clutch lever, you separate the gearbox from the engine, which will reduce the restriction, right? Might not be much, but my personal feeling is it starts better if you pull the clutch lever (if it separates).
When in neutral, there is so much drag within the gearbox resulting from all the oil, the entire gearbox will spin, if you disengage the clutch or not..... your choice.
