Have exactly the same predicament waiting for surgery in my garageGot it.
A selection of left hand drills, Torx heads and ratchet, WD 40 and heat.
A couple of hours work but an early scroll script Brembo caliper saved.
Good luck.Have exactly the same predicament waiting for surgery in my garage![]()
Exactly what I did.Tried drilling on a Parallel Twin 500 Ducati that was a rusty blob; very easy to go too deep. Gauge off a separated nipple to be sure of depth.
Drill and knock a Torx bit in there to get some grip.I need to get a set of left hand drills I think. Good job Paul. I have a couple of halo brembos with broken nipples somewhere.
Thread is fine.If your nipple has snapped off undoing it using a perfect hex head you’ve got to consider how ,after much risky drilling ,you are going to remove the stuck taper? Torx head will spread what’s left, rather like the unfortunately named easi-out. I have been removing these for thirty odd years and have never had to drill any of them and haven’t buggered a caliper up. Remember you can’t helicoil or run a tap down the nipple thread- Paul has managed to remove the tapered end but it does look like the drills wandered to one side, compromising the thread.
Mig welder trick never fails.
