TeddyG
- Portland Oregon
I'd like to fit Lucas turn signals on my 750 that came w/ none. When I depress the turn signal to the right a chirping sound comes from the flasher relay but is quiet when turned to the left, so I'm thinking it needs replacement. Will a generic flasher relay work or does it need to be this exact part number? What is the flash rate on this relay? I tested a spare turn signal to the green and black grounding wire and it only turned on w/ no blinking.
Advise/info is welcomed thank you
