Dellortoman
- Tasmania, Australia
cbertozz said:So with the m.button the lights can be turned off.
From what I've read, all the M-Button does is remotely switch the M-Unit outputs. I've not found anything in the Motogadget info to suggest that it changes the functionality of the M-Unit itself in any way.
However, I take back what I said before about the light switching. The original version of the M-Unit had no way to switch the lights off. But the current model the M-Unit (both the basic and blue versions) does have a way to turn the lights off if you're using a push-button to toggle between high and low beam. If you hold the button in for a 2 seconds the lights will switch off. It's all in the programming of the unit.
The option to switch off the lights is still not available when the unit is configured for the normal Laverda handlebar switches which are continuous contact (not a momentary contact push-button).
Here's the relevant blurb ...
"If a pushbutton is used for high/low beam control, a short press will toggle between high and
low beam. Pressing the pushbutton down for 2 seconds will switch the lights off completely.
Pressing the push button again will switch the low beam back on. A very brief press of the
pushbutton will activate high beam fl ashing.
When using a switch for light control, it is only possible to toggle between high and low beam.
Please refer to connection diagram."
I wonder what the difference is between a "brief" and "very brief" press of the button. Is it possible to inadvertently activate high beam flashing when you want low beam if you mis-time it?
Hey Grant, they also say it's waterproof
"The m.unit is made of a newly designed high-performance thermosetting plastic and is resistant
to moisture, heat, cold and vibrations"
