Manifolds, Mikuni's and a measure of contentment
Looks like the Aprilia one I bought for my Pantah,you cannot extend the lower arm on a cable clutch Pantah,it ends to close to the case and mine was bloody close to the hard pull of my 3C,the Aprilia one reduced the pull to an acceptable amount,and yes it also needed a bigger hole for the nipple.The upper cable adjuster isn't as nicely done as the Laverda one though.Good for my application
Do you have a problem with the extended actuating arm hitting the case? This is why I couldnt use this device.
From my understand I have a standard set of Reds Rods and Balls (insert joke).
If I was to use a longer rod and the wider clutch lever then perhaps this would work.
Many thanks
Ed.
Why would some clutches stick whilst others don't. Mine doesn't (RGS with extra steel plate), lurches a bit on first engagement but certainly not a problem.
I reckon that different types of oil and lack of use causes this.....
