Measurements of a RGS motor
KERMIT1200
Worcester,UK
Hi all,
A friend has acquired a Binnion frame,its one of the frames Graham built to fit around a over bored GS550 engine - F2 racing.
He is thinking of fitting a 120 motor from a RGS.
Can anyone tell me the width between mounting points front and rear,distance between front and rear,height of motor?
Second question - The 120engine in the 120 Jota did this model have the same mounting points with regards the engine as the RGS models that followed?
PS Does anyone have a 120 engine for sale?
Andy,
The RGS and Jota 120 shared the rubberized mounting points.
If you want to mount the engine solid, the front side and underside lugs need to be drilled/tapped, the mounts are then identical to 180 items.  Height of the engine is more or less the same, the cam cover is just a bit smoother.
Have not presently got a 120 on the floor to measure, sorry.
The triple engine will be taller and longer than a 550 Suzuki engine.
I would think that to fit it to the frame would need to be cut and stretched.
What this would do to the handling is anybody's guess, but I don't think it will make it better.
