okay, so you have a two magnet set up which is same set up that Volker used on his latter Hall Effect ignitions
was not certain how your unit worked as that trigger in your photo is huge
twin magnets will be set up as 1 x south pole and 1 x north pole, first magnet (South) in the direction of rotation will switch the Hall Effect trigger on as it passes, second magnet (North) will switch the trigger off
doubt that info will help you but at least you now know how the system works
