MonkeyTS
- Cheshire United Kingdom
Hi Clem,There is a lot you can do to unstick the plates of the clutch without dismantling, but it is not for the feint hearted and since you say that you are not confident to open the primary chain case, then that may well include you, the value of the bike will drop because of the missing red coach lines by quite a margin.
Koni rear shocks were not factory, they were Marzochi and it was Calere (Steve Winterton, just to be picky)
I also have owned one longer than I have had kids, 42 years and counting, and the wrong side of 250,000 kilometres
it does look like a series 1 and they are very rare, (almost all TS's are series 11) I will wager the number is in the 2604 to 2614 region, and if I am correct the primary cover, if it does in the end have to come off) is a very easy thing to do, a bit more complicated if its a series 11 with the ignition buldge on it.
with the clutch sorted. and MOT/tax exemption declared at DVLA, my suggestion is £9500
I will give you £5000 for it
Sounds like mine is a series 1 TS ? number 2988. You mention it's a very easy thing to do, if it's a Mk1. Do I need any specific tools to undertake? As I think I'm going to have a go. Seems the value would be much lower, if it's not sorted. Also Is there anything specific I need to be aware of, must do or not do? Before I remove the Primary case.
Richard
