Hello, I have searched through the Forum to try to find a wiring diagram for my 81 series 1 Mirage with CDI ignition. I have both the Green Book and Laverda workshop manual but neither has the one I require.
My loom has a relay on the rear mudguard that at present is wired as an On/Off switch that is operated by the ignition switch earthing the relay when turned on. This presumably was done to reduce the loading on the ignition switch.
However all the 'parking light' capability has been removed and the pilot light and instruments etc are connected to the main power circuits. The third wire has even been removed from the ignition switch.
Does anyone have a diagram for how this loom should be connected? Or how the pilot light etc should work.
Thanks Andy
Thanks Andy
