jotajoe said:My Jota has precisely the same characteristic. Just a tad of a touch upward on the gear lever prior to a down shift and all is hunky dory.
Joe, Gerald,
This symptom is also very common. The selector pawl that bears on the pins in the outer selector drum is at fault. The teeth of the pawl are just a tiny bit too "sharp". Remove about 0.5mm from the tips of the pawl teeth only and the pawl will slot onto the selector drum pins as it should! No heed for all that fiddling in between shifts.
