motoddrob
- S/W Australia
From what I've been reading I'm leaning towards Vinyl Ester as the resin of choice. Picked up a sample today so will play with it tomorrow. Still might be a good idea to use a lining as well.
redax5 said:"The corrosion is actually from the water trapped in the meth...in the float bowls you could see a "ring around the bath" where the water was on top of the fuel."
Not quite correct, Methanol is actually a weak acid which attacks the oxide coating that normally protects aluminium from corrosion.
Resulting in methoxide salts which themselves soluable in methanol.
Basically, you wind up with unprotected shiney aluminum.
Did you also know that in 2006 astronomers using the MERLIN array of radio telescopes at Jodrell Bank Observatory discovered a large cloud of methanol in space, 288 billion miles across.
Now just need to figure out how to tap into the methanol cloud.
redax5 said:Did you also know that in 2006 astronomers using the MERLIN array of radio telescopes at Jodrell Bank Observatory discovered a large cloud of methanol in space, 288 billion miles across.
Davo said:I can just see it now, Methane powered Jota flying past, blue flames out the exhaust and leaving a filthy stench behind![]()
GregT said:here in dairyland central a medium size dairy unit locally is only about 3000 cows....and there are cropping /sheep farms being converted to dairy units on a weekly basis....
