Montjuic /Alpino Starter Motor Wanted
RayChappo
UK
The spline on my Montjuic starter motor is worn and I'm trying to located a replacement.
Does anyone have a 500 starter they'd like to sell?
Thanks
Ray
Hi, I have got one left over, but it also shows wear at the spline....
gegards
Gunther
gegards
Gunther
Hi Gunther
Thanks for the reply, that has about the same amount of wear as mine, I think it's a common issue.
I'm thinking of making a 10mm aluminum plate to go between starter and cases to move the starter out so the good bit at the end of the spline shaft engages with the starter gear, it's worth a try I think.
Regards
Ray
Hi Ray,
I found out, that the starter motors of Benelli 650 Tornado and some Guzzi/Benelli four cylinder engines have the same Bosch number stamped in as the Lav500 starter.
So you may look for such a starter...
Regards from the alps
Gunther
Thanks for the info. Gunther, I'll keep a lookout 👍
