Lyndoneil
- Towcester uk
Ok, nearly finished the heinous sin of building a montjuic replica, all built up, S1 cams, Monty exhaust, jetted up on carbs, runs so long as it's 2500 revs, standard pistons, new rings (as far as I can tell, despite talk of montjuics having HC piston, they never did, maybe I will be corrected).
Anyway! Couple of problems!
It's seems to be blowing oil from the top, as far as I can tell it's where the bolt that holds the camchain tensioner goes through the head?
Other problem is difficulty selecting gears, gets them eventually.
The workshop manual states the gear selection is maintenance free, any problems are down to worn gears. Then there's a whole page on setting up the gear selector?
Anyone had similar and successfully sorted the problem, I know it's left crankcase of job, but I want to keep it together for now as it's not registered, and want to get it MOT tested, so I can apply for reg plate whilst I sort out the last problems.
