Hi Rob.Looks like you're trying to use a 3 phase reg/rect (3 yellow wires in plug) with the single phase two wire Monty alternator.
It would help to know the make and model of the reg/rect. I'm assuming that the 6 way plug is from it? The brown wire is likely the positive 12v dc output and black is the ground wire but would be good to check with a wiring diagram before blowing it up,
You should also bin those horrible pre-insulated spade crimps - they seldom provide a reliable connection to the wire.
The brown wire is the actual regulating voltage output sense wire on the RR, to mitigate endless drama, connect it to the Red/White wire direct, it will slow discharge the battery over a long period of no engine running periods. Additionally the Black wire from the RR as best practise connected to the actual negative terminal of the battery. This has been addressed endlessly over several decades on the forums. HTH j. BTW the connection you have made of the brown wire will most probable cook the battery if it works at all.I haven't got as far as starting the engine but what I have figured out I think is as follows.
Yellow wires are not an issue.
I have a white and Red out of the RR this connects to the 25amp fuse via a white cable in the loom. The black wire out of the RR is earth. Which on leaves the brown out of the RR which I have connected to a blue and red in the loom which goes to the charge light in the rev counter. I still don't have an illuminated charge light when the ignition is on. But reading some other info might not be the case as its not a built in function of this RR. Any further help would be greatly appreciated.
Reg Tony
Firstly I really appreciate your help many thanks. The black wire connection now gives me the answer to why there was an additional earth wire on the RR plug when I received the boxes of bits that were supposedly a Laverda. Just for clarity the brown out of the RR needs connecting to the Red and white out of the RR do I need to connect the white wire from the loom into this connection which goes to the fuse box.The brown wire is the actual regulating voltage output sense wire on the RR, to mitigate endless drama, connect it to the Red/White wire direct, it will slow discharge the battery over a long period of no engine running periods. Additionally the Black wire from the RR as best practise connected to the actual negative terminal of the battery. This has been addressed endlessly over several decades on the forums. HTH j. BTW the connection you have made of the brown wire will most probable cook the battery if it works at all.
After you Rob, saves me a typing fingers cramp....no problem, grin. As you indicate, there are best choices and not so reliable choices. Sense wire via incandescent lamp would/should work, though drawing low current through various types of metals can produce high resistance contact to contact over time, or lamp going open circuit. Wetting current is a new topic here, sure the lads will be well pleased at the prospect.... a wry smile here. j.Hope John doesn't mind me jumping in -
Assuming the instrument wiring is standard, I'd suggest not! The blue/red wire is being fed through the charge warning lamp from an ignition switched supply via the fusebox. So it shouldn't be permanently live - which is good. Nor will it be providing an accurate indication of battery volts due to the charge lamp resistance - which is bad!
There's a wiring diagram in the library - https://www.laverdaforum.com/xf/resources/54/ - p.139 of the 350/500 workshop manual
Go Tony, your doing well, your appreciation is noted, above that your willing to learn new skills, at times that learning process is daunting or similar. Once there was a time any "new" noise from the Laverdas' caused panic.... then new skills were acquired in restoration and repairs, over time. After some time, even a nuked crank did not produce panic, out with the crank pressing jig and fix it... self satisfaction has much merit. No doubt Tony you will be well happy, in bike and self, well done you. j.Dear All.
I can't thank you enough for the help and patience you have shown in helping me get this sorted. I am not great electrician my skills are more mechanical for sure.
It's been a pleasure in chatting with guys who know what's needed.
Reg Tony.
