My fairing mount bolt decided to give up the ghost over the weekend so need to replace.
From what I can gather my setup is slightly modified with the fairing mounted a couple of inches further forward, which must put some strain on the components. The guys who set it up used a hex coupler between the mount and the frame. The bolt that was used sheared just inside the coupler.
I have a 12.8 steel bolt that will do the job I think but wanted to create a more robust mount setup but I know that if I just fit a stronger bolt I’m potentially putting more strain on the frame mount.
i have no welding skills so anything I do will need to be bolted together. Was thinking of running the bolt through cylinder of solid nylon so both the mount and frame are in contact with a larger surface and there might be a tiny bit of flexibility in the setup.
Anyone tacked a similar problem and found a long term solution?
