tom3c75
- Cape Town South Africa
I'm in the throes of fitting an Ignitech to the RGS.
Question for those who have already done this: Where did you mount the black box?
Options I've thought of include:
(1) On a plate/platform in the tool tray area. Unfortunately I don't have an RGS tray, and fabricating and fitting such a plate is not as straightforward as it was on the 180's.
(2) On a vertically mounted plate fitted to the frame behind the left (primary) side cover.
(3) On the existing bracket that on which the three existing ignition boxes are mounted, this behind the right side cover. However, I'm a bit concerned about debris thrown up by the drive chain, and also heat dissapated by the voltage regulator, which is mounted to the existing bracket.
I've previously always mounted the black boxes placed flat and horizontally. Would it be OK to mount them vertically and, if so, should the connector face down or up? Down seems safer, as any water or other spillage would have less chance causing problems with the connections.
Any pics of what you've done would also be useful. Anyone have a spare RGS tool tray?
Thanks
Tom
Thanks
Tom
