depends on how you wish to do the crank pressing, am certain other people do their cranks different to the way I do mine
many years ago I spent around 8 days straight machining up my crank fixture and various spacer plates etc, is probably way over designed and is heavy as fuck but still works great
I start with the Inner web of No 1 and the No 2 web, so this is the point where you set the phase to either 180 or 120
My fixture is machined to accept the Big end pins, 36mm and the central hole in the plates is 35mm
Middle plate is bored to centralize the Outer diameter of the webs
To start, set press up, position fixture and middle plate
Position 1
Position 1
Next I load the No 2 Conrod web in the bottom, this is because it is easier to position the Main bearing that way
Outer Conrod web Big end pin positions in the top plate and I use split full size machined spacers not to control the spacing so much but to control deflection when pressing offset to the center line
Position 2
Position 2
Then remove the two pressed up webs on turn them over so now No 1 Conrod Big end pin is in the lower plate, move Middle plate up to position itself on the No 2 Conrod web and then keep building the crank up
Position 3
Position 3
Position 4, shows the 180 pressing off No 1 and No 2 Conrods where I turn them over and also shows the spacer plates to spread the pressing load for future webs
Position 4
Then install Number 2 Conrod, I use ground to size steel blocks to control the side clearance on the Conrod thrust plates, top press plate positions the next web in this case on the center line of the crank, press web on, normally they go on in the 8-10 ton range
It is this web and the inner web for No 3 Conrod that I refer to when saying they are difficult to manipulate due to the fact they are pressed on using the centerline of the crank
Position 5
Position 5
Position 6
Shows inner web for No 3 being pressed on
Position 6
Position 8
Shows right hand web being pressed on
Position 8
Position 10
Crank is together apart from outer web for No 1 Conrod that I do seperately
Position 10
Crank out of the fixture, easy as, now just to do final straightening
Final from Jig
Or before you even start, machine off the Oil Slingers, get the grinder out if you don't have a Milling machine and drop 4.5 kgs off of the crank weight, press up new Oil slingers, roll them on, press crank together without Conrods, give crank to Crankshaft Engineering to balance, then strip crank, add Conrods, press back together and go racing
IMG_0885
