Andy,
I don't see any valve seat protrusion.
If you listen to your local expert he is saying the seats need to drop further in by 1.0mm, means the valve tip is now 1.0mm further towards the cam lobes.
You already have a clearance problem on the other side, can see that as it looks like it was run without shims.
I would not be listening to this guy I'm afraid.
Send the head to Keith, it needs to go to someone who has experience setting these heads up.
First though, measure the overall length of the valves and tell us what it is.
Inlet should be ~ 86.3mm
Exhaust should be ~85.6mm
Also measure machined face to machined face of the head, should be ~ 94.0mm
Will give us some more info to work out what is going on.
Good luck
Red
Good luck
Red
