During a long ride late last year I noticed a slight oil leak so I decided to fix that along with the oil change. The leak was from the clutch cover which is under the gear selector and cover, as mine has the hydraulic clutch and not wanting to have to bleed it I left it attached and in moving things around I noticed the thin cover/washer that keeps the pins in place had slid off, but did not check the selector pins, luckily I found it in the used oil where it must have dropped.
I was very impressed with the prompt response to my original post, I must be getting senile and did not realize what the pin was, but the help from this forum is invaluable.
Thanks all.
