Dennis said:Seems like the retaining bands for the Nippon Densos are getting more and more difficult to find. The firms that repair the instruments are generally reluctant to reveal their sources. They really shouldn't be that difficult to make if you have access to a lathe and can source out thin wall tubing of suitable dimensions. I have the plans and process in my head and will give it a try sometime. It is possible to remove the rings with minimal damage anyway so you can reuse them. Basically my process is to use a steel pipe with the inside machined out so the clock will fit in snuggly; then you can carefully pry back the ring without distorting it. Reassembly is basically the reverse. When you reattach the faces be sure to put a tiny drop of paint or mild Loctite on the 2 screws. Very annoying when you see a little screw dancing around at the bottom of your tachometer after a couple of hundred miles.
Dennis
Ha ha Been there Dennis ..Got the loose screw T shirt !?
motoddrob said:Davo, my BM gs100's speedo is on route back from Ottos this minute. $220 to refurbish. I'll wait till I see it before commenting! Sent off 2 months ago so don't be in a hurry. Does good work I'm told.
Xav said:I regained the site on the dismantling method and reassembling ND
Regards
Xavier
Xav said:Go see this site
http://www.ddmototeam.com/pieces/articles_result.php
Hi Xavier,
Do you have an electronic version of documents with the instructions for dismantling in English? I am in Australia and my French is rather rusty.
Avez-vous une version ?lectronique des documents avec les instructions pour le d?montage? En anglais? Je suis en Australie, et mon fran?ais est tr?s compl?te de l'oxyde ferreux.
Thanx Dellortoman, must have had a page redraw issue cos didn't see the link. Blame it on a cable broadband speed that is more like dial-up at times....don't get me started on Telstra here in Australia (vents loudly, grinds teeth, mutters curses in many languages). Better speed this afternoon......Dellortoman said:Which instructions instructions for dismantling are you referring to? I couldn't find any on the ddmototeam site.
These instructions that Xav posted (http://www.salocal.com/sohc/tech/speedo/spedo1.htm) are in english.
Cam
springsoft said:Xav said:Go see this site
Hi Xavier,
Hello SpringSoft
I do not think your French is so rusty. (and it's kind of you to have made your effort in French)
Little translation help:
when you write my French is Rather rusty, translation is mon Fran?ais est un peu rouill?.
To return to what's bothering you, Cam showed you the right path. It's on socal.com site that you'll find the instructions
I will apply to DD Moto Team to give us his parts prices and the cost of shipping to England, the United States, Australia and Europe
Xavier
