ND Tachometer repair or replacement needed
minigunz
Hello folks
my 1971 SF 750 needs an ND Tachometer replaced or I need a contact to send it to get it repaired.
I have not contacted Wolfgang yet he might be on vacation.
He is priceless for parts he has helped me out with on the 3cl and the SF 750.
Any help or info would be greatly appreciated.
Jeff / Minigunz
My understanding has always been that these are Honda Nippon Nenso units with only Laverda branded faces plates, along with Honda switch gear, so what electrical or physical differences ( if any) do these have? Anyone who can repair a Honda unit should be able to repair these, unless they contain special parts which is doubtful. So far I,ve been able to remove the bottom plates and replace bulbs no problem.
Suzuki switch gear!!
There are differences in the clocks. gearing and the trip reset come to mind. If you specialise in one you should be able to refurbish the other.
Hello folks
Jeff / Minigunz
Good call on that State side ND instrument restorations.
Found Randy's cycle service who specializes in ND Tach and Speedo repair and restorations.
Email ( info@rcycle.com ) for a quote.
Closed on Mondays, Tuesdays and Thursdays.
Thank you all for your help.
Jeff / Minigunz
