swisspace
I am finally getting around to rebuilding my laverda with the help of a swiss laverda racer after a failed start on my own quite a few years ago, engine is in the frame and now I am starting on the electrics, about 10+ years ago I bought a new unused and complete John Wilson IIS TA180 system from the UK and I thought I had all the parts however after a few moves I am missing the white plug that is left off so that the wires can be thread through the casing. I have seen some photos in the installation guide but the resolution is no great and there are 5 wires but 6 connectors so I am not sure which should not be connected. I believe the original plug had the cable colours marked but as I no longer have that does anyone know the correct sequence - I have found the correct replacement white plug but now I am stuck on the order - so if anyone knows it would save me a lot of dismantling and time looking at the board to work out which is which - thanks in advance
