You are not in neutral...again.... sorry, couldn'resist
If you disconnect the switch, then connect a multimeter to the switch connection and earth, you should have continuity with neutral selected. If not, try selecting away from neutral and back. If still no continuity, either the switch is not being activated, possibly due to too many washers being fitted, or it is kaput. Remove the switch and depress the plunger by hand with the multimeter still connected to confirm if it is the switch.
