TOMMY666BIKES
- derbyshire
Puller comes in the kit…If you can determine TDC and vaguely read an electrical circuit, the Ignitech is easy to mount and set.
You'll need a puller for the alternator flywheel.
The puller for the Redax kit, yes, not the puller for the original flywheel if I remember correctly.Puller comes in the kit…
And using a 5mm seal rather than the 7mm as recommended by Red.Join the ILOC and you can hire a puller for the original Bosch alternator. You'll only need it once to fit the Redax kit, so no point buying one
It's well worth replacing the alternator oil seal at the same time, as recommended in the very detailed Redax instructions.
