1969mustang
- Alberta Canada
Im getting a set of Bridgestone BT46 fitted later in the week to my 1981 Jota, Standard size tires, Cast wheels.
Ive ordered new tubes, but just found that the tires that are fitted are in fact tubeless and have the valve adaptor / sealing device inside the rim, i thought it was a tube until i removed the 10mm nuts and it dropped inside !
Im of the mind that i will run tubes in the new tires , is this the right decision ? im wary of rapid tire deflation, particularly on the front ,
Most of my riding is black top / sealed but fairly quiet roads, so not a lot of traffic and sketchy cell coverage ? any thoughts on that ?
The Original front tire has always lost air when parked.
With tubes fitted what are the availabe options of a roadside repair in case of a flat,,, other than tire removal and tube patch ??
Thanks
Thanks
